News & Embedded container
amaurydixx
Re: News & Embedded container
Post by amaurydixx »
Yes! Great!
Again: how do you update your News?
Note, that it's a dynamic container. Meaning the news/files are resolved at the time when they are played and not when they are scheduled. Eg. if you modify the news category in between different tracks might be used.
v3.0.14.14 is now available and should fix your issue.
Note, that you need to (re)create a new playlist file in order to get it fixed.
amaurydixx
It seems that the patch solve the "one loop" problem but do not solve the "TRACK ERROR" problem when I use a container which contains a news.
So, I always have to use an extra script to insert a news.
Strange, the embedded News container is working here as well. Do you also only get the track error once saved to playlist? I can not reproduce any track errors here ...
