Remove played is set but not removed.
Re: Remove played is set but not removed.
A few screen shots might help.
You might also try the v4 to see if the issue appears there as well?
3 screenshots:
1. You see the tracks that have not removed.
https://dl.dropboxusercontent.com/u/683 ... 102217.png
2. I manually removed those tracks
https://dl.dropboxusercontent.com/u/683 ... 102600.png
3. Later a new one appeared
https://dl.dropboxusercontent.com/u/683 ... 110527.png
Look at the "Last Played at" column.
I PM you my script. I don't see something wrong. Do you ?
Will take a look tomorrow!
ProppFrexx would never 'reschedule' or randomly insert 'old' tracks! And for sure ProppFrexx would never add tracks already marked as played.
So may be you are using some funky Script-Rules where you constantly 'defer' script-line results?!
And those deferred tracks are later added back again?
From those screenshots I can only see, that they are originally coming from your script.
I have not updated my onair pc yet. I might do it tonight.
I am testing on my backup pc for a few hours and it has not happened in v4 with exact same settings as v3.
As you are currently testing the v4 - did this issue ever happen in the v4 so far?
I assume this is fixed in the v4.
