Playing 1 hour file with ads
ketofm
Re: Playing 1 hour file with ads
Post by ketofm »
ketofm
Post by ketofm »
From that screenshot it looks, like you habe activated the mode ‘Manual Live-Assist’. In this manual mode, you want to start the next track manually. Just deactivate this mode, to start the next track automatically (which is even the default).
ketofm
Post by ketofm »
Thank you so much but I have one more after the playlist playlist finish it does not reload it just stops how can I make sure it reloads loop so it runs 24/7
A playlist does not loop, a script might do. But that depends on how you have defined your programs as well as your script?!
A manually started playlist would also not loop.
Maybe this link helps: https://www.proppfrexx.radio42.com/foru ... p?p=12#p12
