even distribution of songs
D3R3K
Re: even distribution of songs
Post by D3R3K »
Bernd, I found the proppfrexx statistics exe file. How ever it does not function i can open the statistics folder which does open but when i try to import tracks it says there are none available. whats next?
D3R3K
Post by D3R3K »
here is what i see
Have you enabled the global statistics? If yes, a ‚stat‘ folder in the AppDataUser folder will be created and filled with a .stat file per day.
You need to open such stat file.
So please check, that the folder is not empty and the .stat files do exist.
Radiostar929
Post by Radiostar929 »
Bernd, What is the best mode to use for just playing songs with minimum repeats in proppfrexx automation mode. Random or sequential?
See 2nd post in this thread.
Use the ‚LastRecentlyPlayed‘ mode in a script-line.
Radiostar929
I dont see your response of sept 12. am i missing something?
Radiostar929
oh i seeit now
Radiostar929
got ya so if the mode is to be last recently played what should the option be?
You can leave the default options. None is sufficient , except you have extra needs.
Radiostar929
That works fine now I think I'm figuring this out. So, if you have folders of music ranging from 10 to 20 songs, what would be the best mode and option to get a variety of plays in the system?
