Player empty on Tagger
Re: Player empty on Tagger
I am not sure what issue you exactly had, as I can not reproduce it. But if it helped the last time, yes, it might also help this time.
claudius06
Post by claudius06 »
Thank you. One more question: in this directory, there is also a subdirectory named “OC.” Is it safe to delete it?
Make a backup of all first. Then remove all.
If you need files you removed, you can restore them.
Removing the entire config and all subdirectories is like a fresh install.
claudius06
This tip once again worked very well. I don’t know why I sometimes have this “white window” issue, but in any case, for me, this is the solution that fixes the problem.
Tx.
