v3.0.11.31 - stable
Re: v3.0.11.30 - stable
All above issues have been fixed with the new v3.0.11.31!
Farbo
Re: v3.0.11.31 - stable
Post by Farbo »
I was not using PF for longer time. But since update of streaming server configuration I am not able to connect to streaming server. I get error "Username or password incorrect" although I made no changes to configuration and nothing changed on server too. :-(
Bernd, could you give some advice how to remove this error? I am getting this problem by other server too which I use for testing purposes for this kind of matters.
I use Icecast streaming server.
Peter
Farbo
Post by Farbo »
Thank you Bernd. It is working now.
Peter
Yes.
First make sure to use the latest v.34.
And then you might need to change the following within your streaming server configuration (depending on the server type you are using):
- Source Username: leave this field empty!
- Source Password: provide your source streaming password as configured on your streaming server
- Admin Username: leave this field empty!
- Admin Password: leave empty or provide your admin password as configured on your streaming server (only needed for offline mode)
