Script/Macro in Streaming Servers executed w/o connection
Jhary
Re: Script/Macro in Streaming Servers executed w/o connectio
Post by Jhary »
As far as I tested it today it worked fine, thank you.
I even could open a second playlist.
Now...
how do I get back the current user/listener numbers in the "Network Streaming Monitor" window?
Unfortunately I can not reproduce the issue here - at least with the latest.41 and .42.
So please try to update and see, if the problem still persists.
The only possible reason for such behavior I can think of is, that the server itself accepts the connection but short after disconnects it again....if that happens, there is not much I can do, as this would be an issue of the server.
Right-Click in the "Network Streaming Monitor" and select 'Show Listeners' from the context menu.
