Time Announce at.. the right Time
sun7radio
Re: Time Announce at.. the right Time
Post by sun7radio »
The program/script is running since several hours now, and never a time file has been played/appeared in the Playlist while using the macros in its filename :/
Cheers,
Guy.
Yep - finally you got me ;-)
That's indeed a bug introduced into the latest version - the ${fix_...} have been stopped working.
I Will post an update on Monday to fix that issue!
sun7radio
Post by sun7radio »
I'm glad you found the bug :)
Cheers,
Guy.
sun7radio
Post by sun7radio »
Bernd,
Did you had the time to work on that update ?
Cheers,
Guy.
Yes, but I'd like to also add the other proposed enhancements as well - if time allow it.
sun7radio
Post by sun7radio »
Could you give a time frame when you plan to release the update regarding the ${fix_...} macros issue ?
Not that I am pushing you, it is just for me to plan ahead as this is the only issue that prevent me to go on air with PFOA.
Cheers,
Guy.
Tomorrow or latest on Friday.
sun7radio
Post by sun7radio »
Great, Thanks!
Cheers,
Guy.
Advice needed:
I need to play a time announce every half an hour but with two different scripts.
One script for day (32times) and one script for night (16times).
Is there an easy way of doing this, because the only way I 've found is to create all those (48) overlays manually (which is hard anyway).
Hi
I have already created overlays with adv manager for those hours.
So for every 00min and 30min there is a adv overlay.
When I click CTRL + drag a time announce overlay over that hours the pointer shows that can not copy that overlay to that hour.
