v3.0.13.4 - stable
Re: v3.0.13.4 - stable
That sounds strange, I just tested that here and it works just fine.
What libs are you using? Are you using a Media Library Server and is that updated accordingly?
Does the Find window generate the same results?
v3.0.15.5 is now available and should fix your issue!
