${ramptimems}
djbony
Re: ${ramptimems}
Post by djbony »
Ok, thank you
Re: ${ramptimems}
Upps, sorry, I did misunderstand your previous post! So I corrected it above.
I just tested the ${ramptimems} macro in the latest v4.0.1.32 and it works perfectly fine!
So maybe your media library entry did not contain a Ramp cue point?!
djbony
Re: ${ramptimems}
Post by djbony »
I have set Ramp cue point... This is my process in Tagger:
1. I put new songs to the Temp dir
2. Sets all cue points
3. Move tracks to Trackbard and Export it to the .csv file
4. Move tracks to the destination foldier
5. Open the Powergold and Import the .csv file
Thats all. But Ramp is empty. Here is my .exportformat file (I use PowerGold v11 Export format):
<formats>
<format name="Default CSV" type="CSV" extension=".csv" delimiter="," useHeader="True" quote=""" quoteEsc=""" quoteHeader="False" trim="True" encoding="latin1">
<fields>
<field name="Filename" start="0" length="0" align="left" pad=" ">${filenameandpath}</field>
<field name="Title" start="0" length="0" align="left" pad=" ">${title}</field>
<field name="Artist" start="0" length="0" align="left" pad=" ">${artist}</field>
<field name="Album" start="0" length="0" align="left" pad=" ">${album}</field>
<field name="Year" start="0" length="0" align="left" pad=" ">${year}</field>
<field name="Genre" start="0" length="0" align="left" pad=" ">${genre}</field>
<field name="Grouping" start="0" length="0" align="left" pad=" ">${grouping}</field>
<field name="Mood" start="0" length="0" align="left" pad=" ">${mood}</field>
<field name="ISRC" start="0" length="0" align="left" pad=" ">${isrc}</field>
<field name="Rating" start="0" length="0" align="left" pad=" ">${rating}</field>
<field name="BPM" start="0" length="0" align="left" pad=" ">${bpm}</field>
<field name="TrackType" start="0" length="0" align="left" pad=" ">${tracktype}</field>
<field name="AlbumArtist" start="0" length="0" align="left" pad=" ">${albumartist}</field>
<field name="Composer" start="0" length="0" align="left" pad=" ">${composer}</field>
<field name="Copyright" start="0" length="0" align="left" pad=" ">${copyright}</field>
<field name="EncodedBy" start="0" length="0" align="left" pad=" ">${encodedby}</field>
<field name="Publisher" start="0" length="0" align="left" pad=" ">${publisher}</field>
<field name="Conductor" start="0" length="0" align="left" pad=" ">${conductor}</field>
<field name="Lyricist" start="0" length="0" align="left" pad=" ">${lyricist}</field>
<field name="Remixer" start="0" length="0" align="left" pad=" ">${remixer}</field>
<field name="Producer" start="0" length="0" align="left" pad=" ">${producer}</field>
<field name="Length" start="0" length="0" align="left" pad=" ">${lengthsec}</field>
</fields>
</format>
<format name="Default TSV (UTF-8)" type="CSV" extension=".csv" delimiter="TAB" useHeader="True" quote="" quoteEsc="" quoteHeader="False" trim="True" encoding="utf-8">
<fields>
</fields>
</format>
<format name="All Fields CSV" type="CSV" extension=".csv" delimiter="," useHeader="True" quote=""" quoteEsc=""" quoteHeader="False" trim="True" encoding="latin1">
<fields>
<field name="GUID" start="0" length="0" align="left" pad=" ">${guid}</field>
<field name="Trackname" start="0" length="0" align="left" pad=" ">${trackname}</field>
<field name="TrackNumber" start="0" length="0" align="left" pad=" ">${tracknumber}</field>
<field name="DiscNumber" start="0" length="0" align="left" pad=" ">${discnumber}</field>
<field name="Options" start="0" length="0" align="left" pad=" ">${options}</field>
<field name="TrackEnd" start="0" length="0" align="left" pad=" ">${trackendindicator}</field>
<field name="Bitrate" start="0" length="0" align="left" pad=" ">${bitrate}</field>
<field name="Format" start="0" length="0" align="left" pad=" ">${format}</field>
<field name="Length" start="0" length="0" align="left" pad=" ">${lengthms}</field>
<field name="Duration" start="0" length="0" align="left" pad=" ">${durationms}</field>
<field name="Playtime" start="0" length="0" align="left" pad=" ">${playtimems}</field>
<field name="CueIn" start="0" length="0" align="left" pad=" ">${cueinms}</field>
<field name="FullLevel" start="0" length="0" align="left" pad=" ">${fulllevelms}</field>
<field name="Ramp" start="0" length="0" align="left" pad=" ">${rampms}</field>
<field name="Ramp2" start="0" length="0" align="left" pad=" ">${ramp2ms}</field>
<field name="Outro" start="0" length="0" align="left" pad=" ">${outroms}</field>
<field name="FadeOut" start="0" length="0" align="left" pad=" ">${fadeoutms}</field>
<field name="Next" start="0" length="0" align="left" pad=" ">${nextms}</field>
<field name="CueOut" start="0" length="0" align="left" pad=" ">${cueoutms}</field>
<field name="HookCueIn" start="0" length="0" align="left" pad=" ">${hookcueinms}</field>
<field name="HookFullLevel" start="0" length="0" align="left" pad=" ">${hookfulllevelms}</field>
<field name="HookRamp" start="0" length="0" align="left" pad=" ">${hookrampms}</field>
<field name="HookRamp2" start="0" length="0" align="left" pad=" ">${hookramp2ms}</field>
<field name="HookOutro" start="0" length="0" align="left" pad=" ">${hookoutroms}</field>
<field name="HookFadeOut" start="0" length="0" align="left" pad=" ">${hookfadeoutms}</field>
<field name="HookNext" start="0" length="0" align="left" pad=" ">${hooknextms}</field>
<field name="HookCueOut" start="0" length="0" align="left" pad=" ">${hookcueoutms}</field>
<field name="Comment" start="0" length="0" align="left" pad=" ">${comment}</field>
<field name="ModText" start="0" length="0" align="left" pad=" ">${moderatortext}</field>
<field name="ReplayGain" start="0" length="0" align="left" pad=" ">${replaygaingain}</field>
<field name="ReplayPeak" start="0" length="0" align="left" pad=" ">${replaygainpeak}</field>
</fields>
</format>
<format name="All Fields TSV (UTF-8)" type="CSV" extension=".csv" delimiter="TAB" useHeader="True" quote="" quoteEsc="" quoteHeader="False" trim="True" encoding="utf-8">
<fields>
</fields>
</format>
<format name="MUSIC 1 v6 Export" type="CSV" extension=".csv" delimiter="," useHeader="True" quote=""" quoteEsc=""" quoteHeader="False" trim="True" encoding="latin1">
<fields>
<field name="Duration" start="0" length="0" align="left" pad=" ">${lengthms}</field>
<field name="Directory" start="0" length="0" align="left" pad=" ">${directoryname}</field>
<field name="Filename" start="0" length="0" align="left" pad=" ">${filename}</field>
</fields>
</format>
<format name="MUSIC 1 v7 Export" type="CSV" extension=".csv" delimiter="TAB" useHeader="True" quote="" quoteEsc="" quoteHeader="False" trim="True" encoding="utf-8">
<fields>
<field name="TrackEnd" start="0" length="0" align="left" pad=" " mapping="TrackEndIndicator">${trackendindicator}</field>
<field name="Comment" start="0" length="0" align="left" pad=" " mapping="ReplaceCRLF">${comment}</field>
<field name="ModText" start="0" length="0" align="left" pad=" " mapping="ReplaceCRLF">${moderatortext}</field>
</fields>
<mappings>
<mapping name="ReplaceCRLF">
<map value="${CRLF}">-CRLF-</map>
<map value="${CR}">-CR-</map>
<map value="${LF}">-LF-</map>
</mapping>
<mapping name="TrackEndIndicator">
<map value="|">Cold</map>
<map value="\">Fade</map>
</mapping>
</mappings>
</format>
<format name="PowerGold v11 Export" type="CSV" extension=".csv" delimiter="TAB" useHeader="True" quote="" quoteEsc="" quoteHeader="False" trim="True" encoding="latin1">
<fields>
<field name="GUID" start="0" length="0" align="left" pad=" " mapping="TrimGuid">${guid}</field>
<field name="Ramp" start="0" length="0" align="left" pad=" ">${ramptimems}</field>
<field name="Ramp2" start="0" length="0" align="left" pad=" ">${ramp2timems}</field>
</fields>
<mappings>
<mapping name="TrimGuid">
<map value="-"></map>
</mapping>
</mapping>
</mapping>
</mappings>
</format>
</formats>
djbony
Re: ${ramptimems}
Post by djbony »
I tested in PFOA and here is works. In Tagger not...
djbony
Re: ${ramptimems}
Post by djbony »
Can I ask to be added to the Tagger? ;)
Re: ${ramptimems}
Yes, the new macro's are only available in PFOA - as written!
So maybe the next time you should be a bit more precise where exactly you want what feature and in which product to be implemented resp. in which product something is not working! This saves us all a lot of time.
