Behringer DX2000USB Pro Mixer
Re: Behringer DX2000USB Pro Mixer
There we go!
Select the WASAPI model and choose the "Speakers (USB Audio CODEC) (SPEAKERS)" device!
That should record your Behrigers mixer output!
In order to not mix the driver models, I would recommend to then also select WASAPI as your model for the Mixer Outpit Channel(s)!
atlantico
Post by atlantico »
WASAP and Speakers (USB Audio CODEC) (SPEAKERS)" device selected. WASAPI selected also for the OUT Mixer Channel.
As a result we have the same situation:
Sound on studio (speakers and headphones) for mic, cd players and playlist; the output (on internet) just the playlist, no mic, no cd´s!
The older I get, the better I was. :lol:
Is there no sound coming into the input mixer? Are the levelmeters moving?
Did you also select this input mixer as your streaming source in the streaming configuration?
Else, we can do a TeamViewer session tomorrow?
atlantico
Post by atlantico »
Sorry, no sound from MIC and CD Players coming into the Input Mixer and level meters not working.
Agree, absolutely, with TeamViewer session. I am going to install the TV right now.
atlantico
Post by atlantico »
The problem with output sound of my mixer was solved by Bernd, thanks to his patience, persistence and knowledge. This I never forget and I don´t know how to say thank you.
PFOA is in my opinion the best and most advanced radio automation software and whenever I need help had rapid and effective response. This is for me one of best aspects.
Thank you so much, Bernd, and sorry for taking your time.
Problem solved.
You are welcome !
Just an update for everybody. The solution was as simple as initially thought.
The Behringer DX2000 comes with exactly 1 USB output device and 1 USB input device. The input device unfortunately indeed only recording the first microphone channel of the mixer.
As such, we simply connected the Behringer main output RCA jacks (the analog way) with the Laptops mini-jack input plug using a normal analog cable.
We just deactivated (in the laptop's sound control panel) all extra microphone enhancements and boost option, so that we can use the laptops line-in jack as a normal input device.
In ProppFrexx we then used this input as a mixer input channel (INP) and used this one also for streaming.
Finish.
All is working good now!
