Scheduling a recurring show
Re: Scheduling a recurring show
Yes, and as you can see, you have also assigned the Slot "Alerts" directly to your Campaign (as I explained above)!
This mean, this campaign is always played when his Slot is due.
So, as you don't want this, removed that fixed assignment, i.e. Edit the Campaign and under 'Assigned Slots' remove it.
claudius06
I understood and fixed my mistake. A big thank you for your help.
One last thing on this subject, I noticed that when I return to programming a campaign in "Dynamic" mode, the field where I mentioned the slot name has changed its content to this piece of code: System.Collections.Generic.List`1[System.String]. Is this normal?
Can you share a screenshot, where that is displayed?
Oh yes, that is indeed a bug. It will be fixed in the next version.
claudius06
OK! Thank you once again for all!
