New mix settings
djbony
Re: New mix settings
Post by djbony »
By the DJ Players (Seque-Editor too).
Hmm, not here - at least not with your files...
However, I'll anyhow change the MixIn behavior internally a bit, as I already encountered some other side effects when cue-pointers later on...
So I guess it makes sense to wait til that next version...
djbony
Post by djbony »
Ok, thankx. I'll watch it and inform :)
Your 'next' track look very long to the left side (before CueIn).
In the DJ Players there is an extra sanity check to make sure, as a next track cannot start before the current one - I cannot see from the pic if that is the case, but that would be one explanation.
Another potential one is, if you enabled ACPD - could that have automatically added a FullLevel and as such shifted the previous Next?
Else, please send me the 2 segued files in question to take a look at.
Above you wrote: "sometimes Next point of previous track moves, even if FullIn of following is not set"
But the files you send me, the FullLevel is set?!
So I don't know what should be incorrect in the above picture?
Ah now I know what you mean. Yes, that's true for the playback in the segue-editor - the playback needs to be adjusted there as well, like in the DJ Players.
Which final mix?
Played by the Segue-Editor or by the DJ Players?
djbony
Post by djbony »
any news? I tested carefully and in seque editor it's looks like perfectly, but on-air it's play like Cue-In default settings...
Not sure what News you expect, in the latest v4.0.1.32 update all was fixed and due to my tests all is working as expected!
Note, that some Mix settings are destructive, e.g.:
Full-Level, but don't fade in: this mode cannot be used subsequently and is destructive, as it removes an existing cue-point! So use them with care and only for automatic playback, as you might not re-edit them once the cue-points have been removed!
This means, this mode can NOT be used in the Segue-Editor and later again in the DJ-Players; but ONLY during automatic playback!
djbony
Post by djbony »
Ok, I'm gointg to test it more...
