v4.1.5.15 - stable
v4.1.5.15 - stable
Version 4.1.5.15 is out!
What's New?
  • New PFL control-commands added
  • New *[TOINT] macro function params added
  • ProppFrexx freezing bug-fix
  • Amazon Image Lookup removed (as Amazon changed their API policy)
  • MODStream and Overlay without playlist bug-fix
  • Segue-Editor memory-leak bug-fix
  • Added NIC to StreamingServer config
  • Advert allow manual campaign ordering per Overlay
  • KeepStreamAlive bug-fix which might result in double playout
  • MIDI_SYSEX enhanced by $PLAIN: mode
  • Parallel Reminder execution bug-fix
  • Reload Cartwall bug-fix
  • Comand Criterion Parser bug-fix
  • EXEC_DOWNLOAD_FILE bug-fix and enhancement
  • LeastTimesPlayed statistics bug-fix
  • new UseLocalScriptRuleChecks script option added
  • new Streaming option UseSongUpdateFilterToDetermineNextTrack added
  • Overlay timer bug-fix
  • AutoWatch Playlist eject tracks bug-fix
  • Embedded Overlay Container Opener/Closer bug-fix
  • VoiceTracking freeze bug-fix
  • Other smaller bug-fixes
  • stable
jbmusic
Re: v4.1.5.15 - stable
Post by jbmusic »
Today i update our studio machine but after thit we lost the GPOI control on our Airence
in the GPOI monitor we see the coding working well, but on PF it's not working.
What could cause this issue.
You need to always update all machines in parallel, as the remoteing lib has changed.
So make sure to also update your other PCs as well.
jbmusic
Post by jbmusic »
thanks for your prompt reply.
the system in our studio is not connected to other systems.
So just a stand alone situation, so thats the strange thing.
What can i do to solve this issue?
The GPOI monitor see the commands from the cartwall as well fader starts but PF is not responding.
Do you start all from the same directory’s?
Else it would be the same.
Have you checked, if the GPIO Client application is really connected to the ProppFrexx ONAIR application? If not, check it’s network connection.
Maybe it suddenly got blocked, E.g. by your Windows Firewall or alike?
jbmusic
Post by jbmusic »
There is nothing changed... all in the same system etc. I will check the firewall
But is the GPIO Client really connected - have you checked that?
jbmusic
Post by jbmusic »
Yes! The lights are green in GpOI
When I use the faders starts and I use the monitor the connection works...
jbmusic
Post by jbmusic »
Bernd, when I check the events and command
In settings and options I did a test on a command.
I get as control command result;
Error: could not dispatch command
Can you please post the full/exact error.
I assume the error comes from within the GPIO client?! If yes, and the client at least is connected (to both the D&R Mixer AND to ProppFrexx ONAIR), I can only assume, that it must be kind of firewall issue.
