Error close proppfrexx
Kekke
Post by Kekke »
https://ibb.co/wdSXcg3
Hi , hoe can i fix this?
When i close proppfrexx i get this error
W11 64 bit . Latest proppfrexx version
Grtz kekke
Re: Error close proppfrexx
The image shows an ‚OutOfMemory‘ error of the GPIO Client application.
This means, that there is not enough main memory to complete the operation.
You can try to reboot your PC. This might solve the issue.
If it happens again, you might need to add more main memory.
What is your current system specifications?
And what other applications are running in parallel?
Kekke
Post by Kekke »
Thánks for the fast reply
I doesnt go away when i reboot the system.
I made a playlist and when i shut down the system this comes up .
Here my system info :
https://ibb.co/Bjkgccy
But I can not do much against an OutOfMemory error.
Please also try to delete the in the error mentioned config file. Maybe it is corrupt and causing the issue.
Kekke
Post by Kekke »
apologies for the late response, but indeed the solution to delete that file from the appdata folder is the solution to solve this problem.
thanks Bernd!
dalleyr
Post by dalleyr »
Hi.
I have the same problem with ProppFrexx GPIOClient.config, which seems to get bigger and bigger every time the connection is closed. (183 428 ko)
key="RESTPassword" is very very very long
I have already deleted the file.
But the problem comes back after a few days.
The error message appears several times when I close ProppFrexx.
Thank you very much!
What error message do you exactly get?
In the above case, the uses did actually not get an error message in the ProppFrexx ONAIR, but in the GPIO Client app.
Is that the same for you?
If not please post the exact error message you get.
Michel67
Post by Michel67 »
I had the same thing last week. I deleted the file on purpose and restarted it after which it didn't happen again.
EDIT: I had this 2x last week when I closed PFOA. In both cases a message (see screenshot). After the second time I deleted the file Proppfrexx GPIOClient config after which it did not occur anymore. In my case PFOA works with an Airlite. GPIOClient memory usage is constant 84.1 MB while overall memory usage is 29%. Anyway it is solved here
dalleyr
Post by dalleyr »
radio42 wrote: 21 Jan 2025 13:06 What error message do you exactly get?
Exactly the same as first message
That was an OutOfMemory error. Meaning the PC has no free available memory.
Have you monitored the memory consumption of the GPIO client application in the windows task manager?
Is it increasing over time? And if yes, what exact interface are you using (connected to the GPIO)?
