Crash while opening Scheduler print preview
I just made ProppFrexx crashing when doing these steps:
Open the Scheduler > Print Options
In the Format tab, I choosed Weekly Style
Clicked Print Preview, and this error happened:
Please let me know if you need additional information.
Quentin
2026-10-03 20:30:53 [v4.5.3.1]:********** Error/Exception Information **********
Error Source: DevExpress.Printing.v26.1.Core.Void ResetMap()
at DevExpress.XtraPrinting.Native.Enumerators.MappedIndexedEnumerator.ResetMap()
at DevExpress.XtraPrinting.Native.NestedBrickIterator.CreateIndexedEnumerator(BrickBase brick, Boolean forceBrickMap, Boolean reversed)
at DevExpress.XtraPrinting.Native.NestedBrickIterator.MoveNext()
at DevExpress.XtraPrinting.Native.BrickNavigator.IterateBricks(Func`4 predicate)
at DevExpress.XtraPrinting.Native.BrickNavigator.FindBrick(PointF pt)
at DevExpress.XtraPrinting.Control.PrintControl.FindBrickBy(Point screenPoint, Page& page, RectangleF& brickBounds)
at DevExpress.XtraPrinting.Control.PrintControl.CreateBrickEventArgs(EventArgs e, Point screenPoint)
at DevExpress.XtraPrinting.Control.PrintControl.OnBrickMouseMove(MouseEventArgs e)
at DevExpress.DocumentView.Controls.DocumentViewerBase.view_OnMouseMove(Object sender, MouseEventArgs e)
at System.Windows.Forms.MouseEventHandler.Invoke(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseMove(MouseEventArgs e)
at DevExpress.DocumentView.Controls.ViewControl.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at DevExpress.XtraEditors.XtraControl.WndProc(Message& m)
at DevExpress.Utils.Controls.ControlBase.BaseWndProc(Message& m)
at DevExpress.DocumentView.Controls.ViewControl.WndProc(Message& m)
at DevExpress.XtraPrinting.Preview.Native.WindowTargetBase.OnMessage(Message& m)
********** End **********Quentin
Re: Crash while opening Scheduler print preview
Unfortunately I can not reproduce your issue.
Here, the Preview just appears as expected.
Can you please send me your program scheduler file, i.e. "%appdata%\radio42\ProppFrexx ONAIR\4.0\ProppFrexx ONAIR.calendar".
Maybe the issue is something with your scheduer, which I can not see here?
Please find attached the calendar file. Please delete it from the forum once you've downloaded it.
Quentin
Quentin
Your calendar fie is also working fine here without any issues. So unfortunately, I can not reproduce your issue.
Could it be a scaling issue? The previous time it worked fine, I was on a RDP sessions at 2560x1440. Now I am working on a screen at 1920x1080, and the preview window is "larger" the the space available on the screen.
Not that I can think of.
Indeed it doesn't make any difference. Can you check the attached file? It seems to be the paper configuration file.
- ProppFrexx ONAIR pfoaps.zip
- (967 Bytes) Downloaded 3 times
I still can NOT reproduce your error.
