Timecode display does not updates
Re: Timecode display does not updates
Have you maybe disabled the timecode bar and instead enabled the x-fader bar?
If yes please switch back to the timecode bar or update to the latest beta version. In the current official version the TimeCode Window is only updated if the timecode bar (underneath the DJ Players) is visible.
SiriusRadio
Post by SiriusRadio »
No, it happend on the fly, there was no indication.
Sunday eveything was oké, yesterday we open PF and the TC screen shows nothing or incomplete info.
Marcel
SiriusRadio
No updates or any of that since then. No.
We'll check one more time to be positive.
Marcel
SiriusRadio
Yes, it keeps coming back -).
Considering to wait till the next update, perhaps the problem is solved.
Then something must have changed on your PC since 'Sunday' - e.g. any Window's or Graphics driver updates?
Have you tried to reboot your PC.
And/or moved your TimeCode window to a different location?
