.net framework crash
rvtienhoven
Re: .net framework crash
Post by rvtienhoven »
I've just rollback to the v4.6.1 .NET Framework. After rolling back, i've restarted ProppFrexx (v.0.1.32)
I use UAC on ProppFrexx.
I've 1 explorer path in Proppfrexx: C:/automatisering
Windows update is set off since oktober/november 2015.
I reboot since 2013 after every update ;-)
I await what is gonna happening now. I hope it runs now normally. If it runs normally, i try to use v4.0.1.39 with the v4.6.1 .NET framework...
Thanks for your help!
Please look above and my initial questions:
You might also rollback to the v4.6.1 .Net Framework and see, if the error disappears in your system...
Are you using UAC?
What Explorer Paths have you defined?
I now also provided a new v4.0.1.40-update with additional checks and a new UI lib version!
rvtienhoven
I have just installed the V4.0.1.40.
When i start proppfrexx, it runs, but I'm unable to switch user. If i try to login, the screen freeze, and the message 'Please wait, changing user interface layout' stay's now for minutes in the screen. There is no error in error.log...
I alse deleted the .layout files, but it doesn't matter...
rvtienhoven
Hmmm
After delete the .layout files and placing them back from an backup which i maked before the update, it looks like it runs now fine...
That is again strange - I also tested this here on 3 PCs and it works perfectly fine.
that sounds better ;-)
