Mic installation.
Nootje2+0
Re: Mic installation.
Post by Nootje2+0 »
NO this is also not working..??
Nootje2+0
Post by Nootje2+0 »
No.. is also not working ?
Which option from the various?
You said with the Delta ASIO Driver you have sound, but the latency is not good!
So if even smaller ASIO buffers are not working, than its the sound card itself which is not good and you should contact M-Audio for help!
Nootje2+0
Post by Nootje2+0 »
No, this is not working..?
Again: which of the options is not working???
You already confirmed, that with the Delta Driver you have sound?!
Nootje2+0
Post by Nootje2+0 »
What am i doing wrong? I get a huge "echo" on my microfoon?
Asio4all already removed that didn't work either, now found this control panel from my sound card (M-audio Delta66)
Can you help me with this? do youn know what it is?
Thanks,
Are you getting an echo? Or do you still have a delay coming from the MIC?
If the latter:
- set the Buffer in the ProppFrexx mixer channel configuration back to 0 (so it only uses the drivers buffer)
- reduce the driver (M-Audio) buffer from 512 samples in steps (e.g. to 256, 128...)
You might also check (in the M-Audio panel) the 'disable asio direct monitoring' - maybe in that panel you already routed the signal to one of the output channels - see the input and output tabs... but that is an M-Audio config thing I am not too familiar with ...
