radio42 wrote: 19 Aug 2020 07:51
You should leave it checked, as else the normal program/playlist couldn’t consider those pre-generated tracks, which might again lead to duplicates.
You can also pre-generate the Delta manually (initially only) from within the the program scheduler - right-click and select Create Playlist Template.
Also note, that you can define a filter for the automatic generation, to only pre-generate very specific ie. only the RVT Program playlists.
So far I know enough. I'm going to test with different ways of generating playlists. Thank you for your help and information.
