Cue points forced?
Re: Cue points forced?
So you are not using a script?! But you are talking about programs and overlays - I am confused.
Regardless , you can set the same option also on your track…
And yes, disabling the option you mentioned above also disables ACPD for any track loaded to a DJ Player.
But… if it is a playlist, you can simply remove the Next cue-point of the previous track in that playlist (ie. you don’t save the meta data to the TAG). So there is no need to have any additional option.
claudius06
Hello Bernd, thank you for your response. You are right, I initially started programming this show using a script, but I also wanted to test broadcasting it via a playlist.
