mouse wheel going crazy
ferryvh
Post by ferryvh »
Hi Bernd, the mouse wheel is going crazy in de directory explorer. The scrolling is going way to fast with a single move on the mouse wheel.
Another problem i have is that sometimes the entire directory explorer goes blanco after clicking an mp3. As this happends i have to refresh the directory explorer before i can move on.
grts ferry
Michiel Bouwmeester
Re: mouse wheel going crazy
Post by Michiel Bouwmeester »
I have found the same problem, after the .28 update the scroll wheel is much to fast. (in the explorer and find track option)
Nothing was changed in those 2 controls. So that sounds like an issue with the new UI lib version I had to use with respect to another bug which they fixed.
So I am afraid I can currently only open a resp. Ticket against their lib, which I will do.
ferryvh
Post by ferryvh »
looks like it's working fine again.
Tnx
Please try the new v3.0.13.29 - it should fix it (a new UI lib is used which should fix it).
Michiel Bouwmeester
All fine again her also, thank you Bernd!
