Searching for tracks takes a long time in find window
Hello
I don't know what i have changed, but since a couple of days searching for tracks takes a very long time.
Question is, what and where can i change in the settings so searching goes quicker?
Thanx
Friso
Thanx
Friso
Re: Searching for tracks takes a long time in find window
Check your Find settings.
Eg the Force TAG Reading option. See right click menus of the Find window.
Bernd
I saw an earlier post in the forum from someone that has also problems during the find. I have gone back to v.29 and there it seems to work ok.
The problem i have with the log find time is in the latest version i downloaded yesterday.
There is absolutely no issue with the latest v3.0.13.31 !
There was an initial rescan issue with the .30 though.
Bernd
I'm very sorry to say, but .29 doesn't have that issue. Now i tested it again in version .32 First search after startup PF search is going ok, but after that it takes a long time. Also have a crasch during refresh of the explorer, and just as we speak after closing PF this occurs.
I'm for now going back to .29
30-6-2014 14:30:29 [v3.0.13.32]:********** Error/Exception Information **********
Error Source: DevExpress.XtraTreeList.v14.1.Void RaiseInvalidValueException(DevExpress.XtraEditors.Controls.InvalidValueExceptionEventArgs)
at DevExpress.XtraTreeList.TreeListContainerHelper.RaiseInvalidValueException(InvalidValueExceptionEventArgs e)
at DevExpress.XtraEditors.Container.ContainerHelper.OnInvalidValueException(IWin32Window owner, Exception sourceException, Object fValue)
at DevExpress.XtraTreeList.Data.TreeListDataHelper.InvalidValueException(Exception e, Object value)
at DevExpress.XtraTreeList.Data.TreeListData.SetValue(Int32 nodeID, Object columnID, Object value, Boolean initEdit)
at DevExpress.XtraTreeList.TreeList.SetNodeValue(TreeListNode node, Object columnId, Object val, Boolean initEdit)
at DevExpress.XtraTreeList.TreeList.OnSetValue(TreeListNode node, Object columnID, Object val)
at DevExpress.XtraTreeList.Nodes.TreeListNode.SetValue(Object columnID, Object val)
at DevExpress.XtraTreeList.Nodes.TreeListNode.set_Item(Object columnID, Object value)
at ProppFrexx.p.a(Object A_0, ProgressChangedEventArgs A_1)
at System.ComponentModel.BackgroundWorker.OnProgressChanged(ProgressChangedEventArgs e)
at System.ComponentModel.BackgroundWorker.ProgressReporter(Object arg)
********** End **********
The error you posted was due to the fact, that you terminated/closed PF while a search/find operation was still in progress. Nothing serious, but should still not happen.
What error/crash did you get with the Explorer?!
Bernd
It looks like the problem is gone with version .14
