invalid url loading stream
AladnaFm
Post by AladnaFm »
We have some issues loading a stream.
mms is working perfect and is playing.
But this url is not working in proppfrexx: http://84.82.1.180:8080/stream/1/
Tried different combinations: http://84.82.1.180:8080 or http://84.82.1.180:8080/stream
All working in media player but not in Proppfrexx
What could be the problem here?
Greetz
Jesper Aladna Fm
Re: invalid url loading stream
You might try:
http://84.82.1.180:8080/listen.pls?sid=1
or
There are exactly the same as you would get as the "Listen" link on the related SHOUtcast server site.
And both worked here.
AladnaFm
Post by AladnaFm »
That did the trick.
It is working now!
But after I did a reboot of PF it worked.
Doesn't matter it's working!
Thanks
For sure it had nothing to do with the reboot.
