Midi Server
OllyDowning
Midi Server
Post by OllyDowning »
Having a few problems with the MIDI server, trying to use a midi device but if I try to open the midi monitor window I get and error saying the midi server is not started, although I have enabled midi and selected an input. I have restarted the software too.
It has worked in the past so not sure why it has stopped.
Thanks,
Olly.
Re: Midi Server
It is hard to say what it could be, A hardware issue? A driver issue?
What has changed since it was working?
Also note, that a midi device can only be used exclusively, eg if the device is also used by any other software PF could not use it anymore. Could that be a possible reason?
Re: Midi Server
Any News?
OllyDowning
Re: Midi Server
I am not aware of any changed, not used the machine its on for a while, not had much chance. The Midi device is exclusively being used by PF and I have not made any changes, I can try to use the midi device with other software and report back.
Thanks,
Olly.
