Insert track
amaurydixx
Insert track
Post by amaurydixx »
Hi;
I have some "problem" when I use the segue editor, especially when i insert an event (track).
The problems are:
- the insert do not appears before i put a point (in, next, out, ramp...) in the initial track
- when the insert appears the wave is not visible (the red block is present but without the wave) and I have to play the track to view the wave
It is important to notice that this problem is not present the first time i insert an event after restart the software.
Thank you.
amaurydixx
Re: Insert track
- The last version
To insert a track:
- I open the segue editor
- Right click on the track (exactly in the place i want to insert the track) / Insert / Track
- I choose the track on the explorer opened
After that, the track do not appear.
I have to:
- put a cue point on the initial track (in, next, out, ramp...)
After that, the track insert appear without the wave and I have to play (Play button in the segue editor) to view the wave.
Re: Insert track
A) what version are you using?
B) how do you inset the track?
Note that any track insert in the Segue Editor adds a new row to the editor. So many by you need to scroll down or enlarge the editor window height to make it visible?!
Re: Insert track
Oh yes in can reproduce it. It seems the UI lib changed an internal behavior here which didn't repaint an added control correctly. This will be fixed in the next version.
Re: Insert track
Fixed in v3.0.14.15!
