Automatic load of current schedule file
benny
Post by benny »
How do i go about getting Propp to start up and load the current Program Scheduler playlist and catch up to current time automatically.
The playlist has been imported from a scheduler. in this case Powergold.
Re: Automatic load of current schedule file
To automatically start/run the scheduler just check the related option in the general settings, section Scripts/Scheduler.
The current program is rolled forward to the current time by default when initially started. Unless you suppressed that within the program options.
benny
Post by benny »
Auto Play and scheduler start automatically but no playlist loads...
benny
Post by benny »
disregard. Re-imported the playlist and now its working fine.
Have you created a related program scheduler entry?
Eg open the program scheduler and use the Import Button. In the import wizard make sure to also create a scheduler entry.
But I am glad it is working now!
