How can I change the recording name into a fixed name
XTended
Post by XTended »
First a good 2015 for you!
Question: for our new website module "Uitzending Gemist" (listen back radioshows archive) I need to change the recorded filename.
For example my radioshow recording looks like "2015-01-03-XTended.mp3"
But now every show has to be the same name: "Audio yyyy-MM-dd HH mm uur.mp3"
How can I do that cause normally the filename of the show is added automatic to "yyyy-MM-dd"
Bert
Re: How can I change the recording name into a fixed name
Take a look to the general settings, section Recording/Encoding.
There you can define the Filename for the recordings.
If you are using the MIXER_OUTPUT_REC_ON control-command, please also take a look to the user manual, as with this command you can specify an optional 2nd parameter denoting a fully qualified filename.
