Schedulers error
djanji
Schedulers error
Post by djanji »
I was trying to open the schedules and it gives me an error:
17.3.2015 7:14:51 [v3.0.15.1]:********** Error/Exception Information **********
Error Message: Parameter is not valid.
Error Source: System.Drawing.IntPtr GetHdc()
at System.Drawing.Graphics.GetHdc()
at System.Windows.Forms.Control.DrawToBitmap(Bitmap bitmap, Rectangle targetBounds)
at DevExpress.XtraScheduler.SchedulerControl.CreateControlBitmap(Bitmap bmp)
at DevExpress.XtraScheduler.Animation.Internal.LastPaintInfo.CreateOrReuseBitmap(SchedulerControl control)
at DevExpress.XtraScheduler.Animation.Internal.LastPaintInfo.ObtainCurrentAnimationInfo(SchedulerControl control)
at DevExpress.XtraScheduler.Animation.Internal.SchedulerAnimationManager.Paint(PaintEventArgs e)
at DevExpress.XtraScheduler.SchedulerControl.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
at System.Windows.Forms.Control.WmPaint(Message& m)
at DevExpress.XtraScheduler.SchedulerControl.WndProc(Message& m)
********** End **********
Re: Schedulers error
That looks like a drawing error caused by your graphics card. This might also sometimes happen, if a Windows Update in the background was performed, but a reboot is indeed needed or a driver update happened.
Can you reproduce the error? Even after rebooting your PC?
djanji
Post by djanji »
When I reboot than it works normally.
Regards
Jani
