exchanging files with defined cue points, commands, etc.
Farbo
Post by Farbo »
If I define cue points, commands, etc. within particular track and I copy it to another machine will this file has its TAG and other settings as defined on another computer?
Peter
Re: exchanging files with defined cue points, commands, etc.
Yes, if all the meta data was saved inside the audio files TAG data (i.e. 'Save MetaData TAG' was used), then CuePoints, Event Data and other meta data will be available.
If you saved the meta data to a separate .pfmd file (i.e. 'Save MetaData File' was used), you need to copy that file as well.
Deann
Post by Deann »
radio42 wrote:Yes, if all the meta data was saved inside the audio files TAG data (i.e. 'Save MetaData TAG' was used), then CuePoints, Event Data and other meta data will be available.
Thank you so much for the explanation!
It is much clearer this way.
