Proppfrexx dies all the time
Dolkis
Post by Dolkis »
PF dies when I change things in the mixer.
When IM trying to go to my DSP it dies
When Im trying to change the out from the MIC1 channel, it dies.
(Usin the latest 64bit system with 64bit DSP from Stereo Tool)
Im using a demo atm, just checking out he sound but I figure that it will be the same on the real version.
Re: Proppfrexx dies all the time
Yes, the Demo is exactly the same, just not registered.
So we should focus what exactly and why this happens on your machine; as this definitely does not happen elsewhere.
So what does 'die' exactly mean?
Is the application crashing? Do you get any errors (e.g. in the ProppFrexx Error.log file or in the Windows Event Log)? or is the sound just stuttering or interrupted for a short moment?
What does happen, if you do NOT use any DSPs at all ?
Is everything working fine if you do NOT use StereoTool at all?
Is it happening also with other DSP/VSTs, e.g. you might thy "TB FIX" from www.toneboosters.com (they have a free demo version as well to play with).
So may be it is a sound card driver issue? May be just a buffer setting issue?
And what driver model are you using (ASIO, WASAPI, WDM)?
Any news?
Or did you find the issue already yourself?
henkelar
Post by henkelar »
Maybe same problem i have??
viewtopic.php?f=7&t=1443
Maybe? Hard to say without any further info.
If you could provide the same info as in the post you refer to, I can take a more detailed look!
But you haven't even answered all my questions in my initial reply ?!
As such, without any further info I can only do some unreliable guessing...
henkelar
Post by henkelar »
Now i have answered :)
// Henrik
So you are the same as the original post initiator?
If yes, I close this one and we continue with the other thread.
See here: viewtopic.php?f=7&t=1443
henkelar
Post by henkelar »
No, im not the same person, it just sounded like my problem to :)
// Henrik
