To prevent this from happening?
Willem
Post by Willem »
Hi.
Is there a way to prevent this from happening / show up on the web export (html) template? Already have used the Exclude From Title Update option. That is working awesome on Tunein, Winamp, and so on, but not on the html template.
https://app.box.com/s/j7w4etske4krrr4inh90me4npmyss0k1
Regards
Willem
Re: To prevent this from happening?
No, not via the html template.
In order to have full control you would need to do the coding on the web side yourself and use the related control commands. Eg. EXEC_SEND_HTTP_GET
In this post you'll find various links to various solutions:
viewtopic.php?f=9&t=1415&hilit=Now+playing
Or
viewtopic.php?f=9&t=759
But as said, that means you need someone coding your web site accordingly.
The html template is always based on the unfiltered playlist history and the song title suppress/exclude filters are not applied here.
Willem
Post by Willem »
Thanks Berend. I will look in to it.
Regards.
