View menu
Frans
View menu
Post by Frans »
I'm using a demo version of Proppfrexx 4.x on a windows 7 machine in 64 bit.
In the main menu there is a button View.
Under the View button there are buttons like Mixer, Find track, Explorer, and so on. None of these buttons seem to work, so i can't open the Mixer and the other things in that menu. There is no error code. It just won't open the first 15 or so buttons (the buttons Playback history, Look and feel and Workspace are fine).
In the other menus (Main, Scheduler, and so on) i don't experience any problems.
Can you please help me with this.
Greetings,
Frans
Re: View menu
Please reset your layout and then try again - it maybe somehow got corrupted.
To reset the layout either use the related button in the Look and Feel section of the general settings and restart ProppFrexx.
OR close ProppFrexx and then delete the file called "ProppFrexx ONAIR.layout" in your ProppFrexx AppUserData folder and then restart ProppFrexx.
Frans
Re: View menu
Post by Frans »
Thank you, it's working fine now.
