Deleted files in explorer
djbony
Post by djbony »
Hi Bern,
many times it happened to me that after running PFOA is irreversibly erased MP3 files from a folder that was set in Explorer. Why?
Re: Deleted files in explorer
ProppFrexx would NEVER delete any files, except for the given 'House Keeping' folder and only if enabled.
See the general settings, section 'Encoding/Recording' and check your 'Rec. Output Path' AND the 'Keep X days' setting.
If you specify a value (other than 0, zero) for the 'Keep X days', then and only then will ProppFrexx delete all audio files in your specified 'Rec. Output Path' older than the specified X days.
To disable this function set the 'Keep X days' value to 0!
djbony
Post by djbony »
Resolved. That was it. Thank you. P.
