License gets expired?
SiriusRadio
Post by SiriusRadio »
Hi
Since yesterday , after using PF for 2 years,now i get a popup with the text that the license expires in 25 days.
That can't be true, can it?
I bought the license. I could not believe my eyes, restarted and now i have only 21 days left. Can someone please provide me with an answer?
Now i see this error!
27-2-2016 10:46:29 [v3.0.15.21]:********** Error/Exception Information **********
Error Message: Object is currently in use elsewhere.
Error Source: System.Drawing.System.Drawing.Text.TextRenderingHint get_TextRenderingHint()
at System.Drawing.Graphics.get_TextRenderingHint()
at System.Windows.Forms.Internal.WindowsFont.WindowsFontQualityFromTextRenderingHint(Graphics g)
at System.Windows.Forms.TextRenderer.MeasureText(IDeviceContext dc, String text, Font font, Size proposedSize, TextFormatFlags flags)
at DevExpress.Utils.Paint.XPaintTextRender.CalcTextSize(Graphics g, String s, Font font, StringFormat strFormat, Int32 maxWidth, Int32 maxHeight, Boolean& isCropped)
at DevExpress.Utils.Paint.XPaintTextRender.CalcTextSize(Graphics g, String s, Font font, StringFormat strFormat, Int32 maxWidth)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcSimpleTextSize(String Text, Boolean useHotkeyPrefix, LabelAutoSizeMode mode, Int32 predWidth, Int32 predHeight)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextSize(String Text, Boolean useHotkeyPrefix, LabelAutoSizeMode mode, Int32 predWidth, Int32 predHeight)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextSize(String Text, Boolean useHotkeyPrefix, LabelAutoSizeMode mode)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextSize(Boolean useHotkeyPrefix)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextPoints()
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcContentRect(Rectangle bounds)
at DevExpress.XtraEditors.LabelControl.LayoutChanged(Boolean isVisualUpdate)
at DevExpress.XtraEditors.LabelControl.LayoutChanged()
at DevExpress.XtraEditors.LabelControl.OnHandleCreated(EventArgs e)
at System.Windows.Forms.Control.WmCreate(Message& m)
at DevExpress.XtraEditors.LabelControl.WndProc(Message& msg)
********** End **********
Will
Re: License gets expired?
This already happened to a couple of v3 users. The reason is a bit unclear, but somehow the Windows Registry entry where the license is kept is lost by whatever Windows update...
To resolve the issue:
Simple re-enter your existing registration data, click on the 'Register...' button and re-enter your Validation-Code and click OK.
This will recreate the registration information in the Windows Registry and all is fine again.
SiriusRadio
Fixed.
Will
louis
Post by louis »
Hello! I'm having the same problem. I don't know where I can find the validation code though? Any suggestions?
It is contained in your original registration mail ;-) Where the key and serial is also contained...
