Mixer, cardwall,find track no longer visible
gerrit
Post by gerrit »
Mixer, cardwall,find track, etc are no longer visible. I don't no what I did wrong. Some times I work
with 2 screens. But when I put the second screen on there is also no mixer or cardwall or nothing
when I activate them. Re-install is no answer. Is there something wrong in my config?
Thanks!
Re: Mixer, cardwall,find track no longer visible
Have you changed your monitors? Is the 2nd monitor not available anymore?
Please try one of the the following:
a) Try to click on the resp. 'Show...' buttons in the "View" ribbon tab.
b) Close and Restart ProppFrexx
c) Reset your layout in then general settings (section 'Look and Feel') and restart ProppFrexx after that
d) go to your ProppFrexx AppUserData folder and delete the "*.layout" files and restart ProppFrexx
gerrit
Post by gerrit »
Option D did the trick. Thanks!
