New script command COMMAND_USER_1_IMAGE_SET
Havenstad FM
Post by Havenstad FM »
During the setup and configuration of PFOA i did setup some user commands and provided some custom images to make it easier for our users to understand the meaning of the different user commands.
It would be nice if it would be possible to change the image once a command has been executed. That way it becomes possible to indicate if a user command is active or not.
This could be done in different ways. Perhaps you could let us assign two different images to a command button in the setup to make this possible. Or you could create a script command to change the image. (ie. COMMAND_USER_1_IMAGE_SET <image filename>)
I think it would become clearer to a user if some function is active or not.
With kind regards,
Jack Reitsema
ITC Havenstad FM
Re: New script command COMMAND_USER_1_IMAGE_SET
A new
SET_USER_COMMAND_IMAGE <index>|<filename>
is added to the new v4.0.1.25 update...
Havenstad FM
Good morning Bernd,
I'm using it now and it works great. Big thumbs up for your support!
As i was playing with the scripting commands i also noticed that there are 50 user command buttons, but only 30 EXEC_COMMAND_USER commands. Was this by design or did you simply forget to create the extra 20 commands?
Regards,
Jack Reitsema
ITC Havenstad.FM
No, that's by design ;-)
