ProppFrexx Just freezing, the music is still playing!
Dolkis
Post by Dolkis »
I do not know how I can describe the problem any better then this.
The whole interface is freezing EXEPT The remaining on the decks (its counting down but very laggy)
The songs are still playing.
I have Autoplay on, streaming to one server, was tabbing from Google Chrome when it frooz.
Using 2 screens, one for PF Playlist, The other for Moderator/trackinfo (3 tracks) Timecode, Onair Time, Main Mixer, Directory Explorer, Find track and Network Streaming Monitor.
I dont have any crashlogs...
Dolkis
Re: ProppFrexx Just freezing, the music is still playing!
Post by Dolkis »
I could not use the ordinary "x" buttom to close the program but I could use the Windows bar to close it, Then some of the interface started to work, but could not click on anything...
What does that mean "...tabbing from Google Chrome when it frooz..."?
...so that sounds like "Google Chrome" causes the UI to crash?
Dolkis
Post by Dolkis »
Yeah kinda, I thiunk that it do not matter what program that Im tabbing from tho. (I think it whas Crhome, it might also have been MSN)
Which version are you using?
And what OS and hardware are you using?
e.g. winXp, Win7 x32, Win7 x64...etc.?
And is the error reproducable on your side...as I can not reproduce that here.
Dolkis
Post by Dolkis »
Win 7 x64 and the latest version stable version.
It did happen 2 times today, ones on the Aircheck before I was going live(just thougt it was a fatal error), and then one time when I was onair.
I can try to reprodoce it tomorow after work.
And there are no errors in the ""Error.log" (contained in the ProppFrexx AppUserData folder) not
are there any errors in the Windows Event Log?
Dolkis
Post by Dolkis »
The only thin I can se that did get an error (but just on the first time it froz) wat .NET Runtime.
.NET Runtime version 4.0.30319.269 - There was a failure initializing profiling API attach infrastructure. This process will not allow a profiler to attach. HRESULT: 0x80004005. Process ID (decimal): 18668. Message ID: [0x2509].
That's really weird, as that message indicates, that some kind of profiler application wanted to attach to ProppFrexx which failed?!
I just released a v3.0.11.9 - so please try that one and make a reboot of your machine, to see, if the issue disappeared with that version.
Dolkis
Post by Dolkis »
Hello, just had Autoplay on since last night around 8, woke up and sat down here, PF was running as it should. I browsed a litle on the web (on Google Chrome, have many windows open) and poof, it just frooze again.
no errors in Event Wiever. No errors in PF. So I do not now how to fix this. Maybe I just need to ReInstall PF and try again?
