Instant recording minimized?
SALTO_Ronald
Post by SALTO_Ronald »
Is there any posseble solution to minimize the instant recording window? I can't find it how to do this and if it's not implemented, could it build in? When you start instant recording, it stays on top while recording.
Re: Instant recording minimized?
Why would you have that minimized?
It can simply be closed and reopened. That saves much more resources and that's why it cannot be minimized at the moment.
SALTO_Ronald
radio42 wrote:Why would you have that minimized?
We use the recorder in the studio's for the people who want to record the whole show. When somebody use the ProppFrexx recorder, it stays on top and blocks out some parts of the screen.
This is why we would like the option to get the recorder minimized during recording. If it is possible, to be it a seperate program that we could start when needed.
To record a whole show, you can use the REC button at the buttom of the related mixer channel. Settings can be adjusted in the general settings for this.
So I assume that there is no real need to use the Instant Recording window for this ;-)
SALTO_Ronald
That would be a nice option to use but because we use limited profiles for different users ( we are a public acces organization ) the mixer tab is not accessible for those users. Because of that we use the instant recording.
Is there a hidden setting setting to maybe set the instant recording to be not allways on top?
When you open the Instant Recording from the ribbon Tool tab, it wouldn't stay on top...
However, in this case I might also add a minimize button to it.
But when opened from another location, e.g. the Trackboard, PFL Player or SegueEditor, it will be opened as a dialog and then it doesn't make sense to provide a minimize button.
