PFOA freezes
PFOA freezes
Hi, Bernd,
I start PFOA (after a fresh reinstall) and can access “Scheduler”, “Tools”, “View”… but when I try to open the folder “Open” PFOA freezes immediately and to close it I need to use Task Manager. It doesn´t matter if firewall is enabled or disabled!
I have created a “dump file”, but I have no idea how can I send it for you because the file has 591Mb. What do you suggest, please?
Regards
Luis
Regards
Luis
The older I get, the better I was.
Re: PFOA freezes
First try to delete the "ProppFrexx ONAIR.layout" file after your reinstall, maybe that got somehow corrupted. Note, that a fresh re-install never deletes all your config files, except yu do this manually.
The "ProppFrexx ONAIR.layout" file is contained in your ProppFrexx AppUserData folder...
Re: PFOA freezes
After delete "ProppFrexx ONAIR.layout" problem solved.
Many thanks for your attention.
Luis
Luis
