Jingle of cartwall starts with a delay of 2 seconds
XTended
Hi everybody,
Something strange here; when I click on a jingle in my cartwall there is a delay of 2 seconds before the jingle plays.
I don't know if it have something to do with the latest update, because before a click on a jingle there wasn't a delay, it was click and direct play.
The only thing I installed this weekend was the Breakaway Broadcasting Processor, but I don't think it is the software that slow down my jingles now.
rvtienhoven
Re: Jingle of cartwall starts with a delay of 2 seconds
I see that I can type in Dutch to you, but than, the other users here don't understand;-)
I had this issue a time ago. It was not 2 seconds but around 500 ms. It was caused by an change in my mixerpreset (DSP).
Did you change something in your mixer preset??
Is the cartwall played in the screen, or is there also an delay after an click on a jingle?
Do you use Breakaway as dsp in proppfrexx or as standalone application?
Regards,
Remi
Another Proppfrexx user from The Netherlands
Regards,
Remi
Just tested it here and I have no delay.
You can simply deinstall or deactivate your Breakaway Processor to see if that changes things back to normal.
In the latest versions there was no change in the cart wall or mixer.
XTended
Hallo Remi,
Yes I changed something in my mixer preset, because I had to change my Yamaha Mixer device into the Breakaway Pipeline device (otherwise no music), see picture after and before.
Please revert your changes to see if that changes your latency.
XTended
Yes deactivate the Breakaway pipeline is the solution...
So Breakaway was adding that latency...?!
XTended
Yes it was Bernd; shall find a hardware solution instead of software. Do you have a good suggestion, cause the sound with Breakaway was very good.
No sorry I don't have or know a hardware solution.
But there are various good VST based sound processors, like StereoTool or ToneBoosters.
