Voice track
adegarde
Voice track
Post by adegarde »
Best forum members, i am a little on the play with proppfrexx and walking against a problem. I would like to make a voice track list but walking against the following to, and that is that ie the list not playing in scheduler so i do what is wrong and hope that you can help my hereby. I proceed as follows.
I open new playlist templates wizzerd, then I get the shamefully to plans on a certain day and time. If I am doing so I will go to the next screen where i the folder and playlist name can change as i do nothing else and leave everything so. Then again I get the auto option start voice tracking and click finisch. Now that a plylist opens and window voice tracking where i folder and file name may change at the bottom of the window, but let it as it is. I shall now proceed voicetrakken and when i am finished I click on OK and then save the playlist on and connect the playlist. When I now the scheduler check I see that the voice track playlist is not listed on the displayed date and time in so he plays the play list.
What is wrong.
Re: Voice track
What options did you exactly select in the wizard?
Eg. did you select the 'Create Scheduler Entry'?
A few screenshots of your wizard settings might help...
adegarde
Re: Voice track
Post by adegarde »
This optie is not select, I select this and now see voicetracking in scheduler and working.
Thanks
