delete sometimes jingels in map of cartwall
Sjeek
Post by Sjeek »
I have question about the cartwall, i use 2 cartwalls and made several map in these cartwalls.
In 1 of the maps sometimes all jingels ar gone so i have put them back in map of the cartwall, I tried several thing but the problems is still there.
Some one a idea what to do?
Sjeek
Re: delete sometimes jingels in map of cartwall
Post by Sjeek »
I call it maps but in proppfrexx it's called library. When i put some jingels in this library they are gone after a while, sometimes after a few hours sometimes after a few days,
Sometimes it works well for a period( even after a several start up with proppfrexx).
I made/changed several times this library(even with other names) but the problem is still there.
I have 4 other library's in the cartwall wich still working good.
I use proppfrexx 4.0.3.24 but problem was there in earlier version,
ProppFrexx never deletes any files, NOR libraries.
The ONLY exception is, if you enabled the House Keeping option (see general settings, section Encoding/Recording) - 'Keep Days':
Set this option to 0 to disable it.
If enabled, audio files in the recording folder might be deleted after these number of days.
Else (if this option is disabled), there must be some other application on your PC which deletes files!
Sjeek
Post by Sjeek »
I checked my house keeping in Proppfrexx "Keep days" was set on "0"days,
Strange it's only 1 library wich de jingels disapear, i made several times a new libary, the problem stay's.
My other 3 library's are working good.
There not much programma's on this computer i use it only for proppfrexx and download music from our server.
I delete some programma's en changed my settings of the virus scanner(AVG).
No, as don't know what you man by 'map in these cartwalls' - what is that a map in a cartwall ??
So please specify a bit more in detail, what exactly is not working.
Is a single cart disappearing or an entire cartwall library?
Also, please specify what exact version you are using, and what license you have.
Thanks
