Last Played At history gone after latest update
TZOR48
Post by TZOR48 »
With the latest update, the Last Played At history is gone. How to retrieve it?
Thank you in advance!
Re: Last Played At history gone after latest update
Nothing changed in this respect with any of the the last updates.
There was also never any 'Last Played At History' window available - so I am not sure what exactly you mean!
Maybe you mean the 'Entry Statistic' settings in the general settings?
If yes, they can now be found under the section 'Logging' - but that has already been changed a long time ago, but maybe you didn't update for quite some time?!
TZOR48
Post by TZOR48 »
I have added a screenshot with the settings (2.) and screenshot what I mean about "Last Played At" (1.), in each folder it shows the same. The history in each folder - it's all gone! And my question is, how to retrieve it?
Thanks!
What you showed me in screenshot 1. is the 'Last Played At' column within the find window.
If this column is gone you can simply right click on the column header in the find window and select 'Cilumn Chooser' and drag the missing column back to the headers.
Note that the entry statistics are not saved per folder, but all in a single file called .entrystats contained in the ProppFrexx AppDataUser folder.
Maybe you or any other app somehow deleted that one or you accidentally clicked on the ClearStatistics button?!
TZOR48
Post by TZOR48 »
No, the column is not missing. The column is there. The data is missing. Where is that AppDataUser folder? I can't find it!
TZOR48
Post by TZOR48 »
What about Windows 8.1?
atlantic
Post by atlantic »
I have the same problem. and the file ProppFrexx ONAIR. entrystats is no longer updated since 12/04/2017( after update). windows 7 en Windows10 de same problem.
Ahh, so it is not gone, but not updated anymore?!
I'll take a look...
Yes, you are right, there was a small bug introduced in the v4.0.3.24.
A new v4.0.3.26 update is available, which fixes this issue!
