Recovery of Instant Recording Recording?? Please Help
megamike
Post by megamike »
help please
i was doin a show and had the instant recorder running and stopped it at the end but now i have no file,is there a way to do recovery or is it lost?
Re: Recovery of Instant Recording Recording?? Please Help
I cannot tell what happened with your file.
Was it deleted by someone? Have you looked into your waste bin?
Or was it not even recorded correctly? Or not saved?
I am afraid that I cannot give you a good answer here. I assume you already looked to your configured recording folder.
If there is nowhere a file it is probably lost.
megamike
Post by megamike »
i stopped the instant recorder when the show was done but did not close the instant recorder window, jus waked away from my laptop and when i started my laptop back up next day i am assuming the mouse was on the start button of the same recorder window and it started teh recorder again and now i cannot find the file on my desktop where it is supposed to be, only this new file thats only 7 secs long and with same date n time as the one im missing that shud be 6hrs long
megamike
Post by megamike »
so essentially what i fear is the 2nd recording started in the same window, deleted or erased the first recording of 6 hours, so im hoping the 6hr recording is sitting in a temp file or something
If you did not press the save button after your 1st, but specified the same file for your 2nd recording then it might be overwritten , yes.
megamike
Post by megamike »
ah, so its lost, thats too bad :( thx for your help
