MODStream Watcher: Fade Out at Stopping
meisterpropper
Post by meisterpropper »
is it possible to add a fade-out functionality to the MODstream Watcher, whenever it should be stopped? Also a button at the MODStream Watcher would be useful.
Little hint: the description of the MODStream Watcher at the control command creation window is not fully shown. Perhaps you can adjust this window setting?
Thanks and regards,
Re: MODStream Watcher: Fade Out at Stopping
The MODStream is already faded out using the general mixing setting: Manual FadeOut Length.
Of course a MODStresm cannot be faded out, if it end premature, e.g. because the server disconnects or get broken.
You can click on the MODStream ribbon tab button (if the MODStream is started, it will be stopped).
Or use the 'Close' button within the MODStream Player.
meisterpropper
So when I set a manual FadeOut Length is this recognized when I hit the button 'Close' at the Modstream Watcher?
I think a FadeOut is possible at the Control Command MODStream Watcher Stop, isn´t it?
Yes, the Manual FadeOut length is used no matter if the MODStreamPlayer is closed via the 'Close' button or the MODSTREAM_WATCHER_STOP command.
No, the MODSTREAM_WATCHER_STOP command does not come with any extra FadeOut parameter.
