adds are not sorted by active filter
vytaut11
Post by vytaut11 »
Hi!
After latest few ProppFrexx updates Advertising and News don't filter adds by "show only active". It is showing all adds all the time.
Here is some pictures from current/latest version and picture from earlier PF version. There "show only active" filter is working properly.
How to fix this issue?
PF is showing only active campain adds
PF is showing all adds even "show only active" is enabled. Adds in Italic are not active and blue underline add is belonging to active campain
Re: adds are not sorted by active filter
Yes, this issue is already know and caused by a new behavior in a new version of the UI lib I am using. It will be fixed in the next verison.
Fixed in v4.0.3.43
