Overlay scheduler and colors in cart walls disappear
Hi Bernd.
Normally PF shows the overlay scheduler, now we just see a small announcement after the upgrade.
The same happens with the cart walls. We've colored the cart walls, now it's all gone.
The problem with the cart wall happens every time.
Do you know the answers?
Re: Overlay scheduler and colors in cart walls disappear
I cannot follow, what announcement do you see? Doesn't clicking on the 'Overlay Scheduler' ribbon menu item show it ?Normally PF shows the overlay scheduler, now we just see a small announcement after the upgrade.
What exactly is gone, the cart wall window or the colored items?We've colored the cart walls, now it's all gone
If the cart wall window itself, please close PF and delete the "ProppFrexx ONAIR.layout" file and start PF again.
If the colors of the items, are you maybe using a folder based media lib and have specified a 'Default Entry Type' with it?
Time, pfffh, biggest issue now. Hereby a pscreen of a cardwall. Sometimes when we update the system all colours are gone. next screenshot in beteween one hour
See above and remove the mentioned .layout file.
