Error while switching between two playlists
Michel67
Post by Michel67 »
17-9-2017 20:06:07 [v4.0.3.71]:********** Error/Exception Information **********
Error Source: DevExpress.XtraBars.v17.1.Boolean get_Enabled()
at DevExpress.XtraBars.BarItemLink.get_Enabled()
at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.CanPressItem(RibbonHitInfo hitInfo)
at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.OnMouseDown(DXMouseEventArgs e)
at DevExpress.XtraBars.Ribbon.RibbonStatusBar.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at DevExpress.XtraBars.Ribbon.RibbonStatusBar.WndProc(Message& m)
at ProppFrexx.ProppFrexx_ONAIR.VyRt(Exception )
at ProppFrexx.ProppFrexx_ONAIR.YyRK(Exception )
at ProppFrexx.ProppFrexx_ONAIR.cyRH(Object , ThreadExceptionEventArgs )
at AI.tB.EydM(String[] )
********** End **********
it was only 1 time, everything just goes on
Re: Error while switching between two playlists
This looks like some issue within the UI lib that I am using. I'll send this report to the vendor and see/hope if they can find anything.
So far I cannot reproduce the issue.
Can you reproduce the issue?
It also looks, that you have pressed a certain ribbon button - can you tell me which one it was?
I assume it never happened again - as such, I am closing this issue.
Michel67
Post by Michel67 »
sorry for the late response.
I pressed the tabs, but it has not happened until now.
Maybe it was already fixed with the latest version(s).
