Check RVT playlist before broadcasting
Is there any possibility to check:
1. the playlist before broadcasting? So we can check sometimes before broadcasting.
2.If we use the scheduler automation, PF generates playlists. Were can we find these files?
3. Is it possible to change these playlistst? This question is related to the second question.
Exciting to hear form you.
Will
Will
Re: Check RVT playlist before broadcasting
to 1: Of course. Just go to the program scheduler, do a right-click on the related program entry and select 'Open Template Playlist...' from the context menu.
to 2: It is the last folder you used for (remote) voice tracking (e.g. as specified in the general settings, in section 'Encoding/Recording' for the 'Playlist Templ. Path' option).
If that was never set, it is defaults to your ProppFrexx AppUserData folder to the "plstmp" sub-folder.
to 3: Yes, just specify a different 'Playlist Templ. Path' option in the general settings, in section 'Encoding/Recording'.
Can't seem to find the 'Playlist Templ. Path' optionradio42 wrote: 04 Oct 2017 15:28
See pic Will
See the picture yourself. It is there, right under the Remote Voice Tracking label. You have even already entered a value in it
